It is currently Tue Aug 12, 2025 1:19 am
 Post subject: Help with brace.
PostPosted: Sun May 22, 2016 10:12 am
First name: Jonathan
Last Name: coleman
City: rome
State: ny
Zip/Postal Code: 13440
So I've been struggling with how to make and replace a broken brace.
I don't have much of a power tool selection so I've been craving it completely by hand with a chisel, and sandpaper. I can make it look great but the struggle is coming from the fact that the back has a radius.
Can someone give me some guidance as to how to get the bottom of the brace to seat properly?
Thanks in advance.
 Post subject: Re: Help with brace.
PostPosted: Sun May 22, 2016 10:39 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Put a matching radius on the brace bottom. You can use a profile copy gauge either on the inside or out of the guitar depending on your ability to get the tool in the guitar. Transfer the radius to a cardboard template, cut it out and then transfer it to your brace. You can use a plane to shape the bottom of the brace. When finished it should be close enough to seat properly. You can fine adjust with sand paper.
PostPosted: Sun May 22, 2016 12:18 pm
State: Tennessee
Scribe a line, take a short piece of a pencil flatten/thin it so your point just touches the high spot on the new brace and draw your line. A sharp block plane and two ,three minutes later you have a perfectly fit brace. Good Luck
PostPosted: Sun May 22, 2016 3:53 pm
Last Name: Cox
Chalk fit it.
Rub a little powdered artists chalk on the brace. When you rub it on its matching spot - it will leave a mark on the chalk. Plane that spot. Repeat till you have an even fit. You want a chalk color that's easy to clean up and doesn't have any dye in it that would get into the wood... I think I would choose white....
These users thanked the author truckjohn for the post: ChuckH (Thu May 26, 2016 10:10 pm)
PostPosted: Thu May 26, 2016 10:12 pm
First name: Chuck
Last Name: Hutchison
City: Houston
I agree with Truckjohn. Get the brace close to radius then chalk fit the brace. Use small plane and scrapper to fit perfect.
Sent from my iPad using smoke signals
